The cp-e intake does is more restrictive than cobb's sri so cobb suggests running their maps for the stock box to compensate by producing more boost. The fuel pump is a waste of money unless you are going to be adding every bolt on there is including a bigger turbo. I would get the wheels or the AP. You may be able to run the fmic maps with the ETS tmic, but currectly there are no fmic maps for the ms cai. You may run into overboosting problems on the stage 1+ map. I would suggest letting the ecu adjust over at least 100 miles before getting on it. Otherwise you may get some killer spikes. Let us know how it works out. I am considering the same setup.
