AFaceInTheCrowd said:howbout we get a stock flange welded on there. like something from a wrx, mr2 turbo, skyline, supra tt or something common like that. that way, we can pick out the valve we want and order it as a bolt on for that car. personally i'de like a wrx flange welded on there. there are lotsa bov/bpvs out there that will fit that.
Torco-MSP said:Mount the bov on the pipe that connects to the throttle body and the intercooler and mount it closer to the throttle body side. Make that pipe as straight as possible with the least amounts of bents. Forget about being able to use the stock bov because no one that modifies their car is going to use the stock one anyways. For the pipe from the turbo to the intercooler make that one as straight as possible as well and dont bother making a hole there to mount the bov, that location sucks...
Other companies already make hard piping kits that are similar to the stock intercooler set up. There need to be another company that takes it to the next level and makes it so the kit performs better and has different options.
If you guys over there want to take it even further try making an intercooler relocation kit.
