h&r or Eibach?
brennan
what lowering spring is better eibach or H&R? which looks better and which gives better performance? also if you use just springs and not buy new struts/shocks do they screw them up?
so buying either would be ok, I heard though that the eibach doesn't look right, back of the car is lower than front?
question, if i buy the kit for like 400 of nopi.com is that the entire kit, will it come w/ everything i need. im totally new to air suspension. is ground control an airbag system and how much is it. also do i lose handeling by adding airbags.
If you want to retain the handling your already have, then definately stay away from airbag setups. Ground Controls come with Springs, Perches and allen wrenchs to lock and unlock the perches. For more info, go to Ground Controls website. They also have camber kits for the protege
