Gte super charger
"Can I wire the supercharger so its always on while the car is on?
No, you must never have the supercharger be on continuously for more than a few minutes or it will cause heat up and damage. This would void the warranty. It is designed to be on for short bursts. It would not take a vehicle more than 30 seconds to reach over 100 MPH, during this period the supercharger would be working when your vehicle is floored.
How does the supercharger turn on?
Included is a micro switch - the micro switch can be mounted under your pedal or next to your throttle body. The switch must only turned on when your floor the vehicle. If your vehicle has drive-by-wire, then the only option is mounting the switch on or near your gas pedal, this is not an option."
LMAO!!!!
(rofl)
And the video "test" is even, ummm, more awesome-er!!!!!
