Ok his car might beat a stock speed6(not mine). I am not wrong about anything else. I just dont see the point of buying this big turbo if you cant use it the right way when you put it on. This turbo is ment to run BIG boost. Which none of you can do yet. Go look at some of the other cars that run this turbo you will see nothing lower then 22psi. (drinks)
Trees is wrong... his car isn't slower than a stock ms6...my buddy who commented has a Subaru so I don't really think he cares so he just called him a newb. He is still making power he is just having trouble (no offense mike but ur car is making power for more than 1k) with the throttle plate closing early. His car is still one of the fastest ms6's around end of story, all I was saying is until he is tunned and cp-e figures out how to keep the throttle plate open, he wont see the benefits of that big turbo.
To everyone,
Sorry you just can't slap a big Turbo on and expect to Be quicker than what your previous setup was!! There's factors that come into play.
For example:
A honda civic with a T25 with 21psi will spool faster and probably be quicker than a new setup.
like a upgraded kit a GT35R with 14psi tuned will probably run around the same power and time's but with less boost!!
You just can't expect MS6mike to run quicker times because he slapped on a turbo-kit. He still needs a Good Tune and build the motor up to run more or equal boost as his previous setup. With that said he will kill any Stock Speed6/ or Modded with the stock Turbo!!
A stock speed6 is faster then him.
His power band will always be 4000-5000 rpms.
What do you mean the throttle closes at 5000 rpm? Wouldn't the car shutdown if this were true? So all ms6 owners are forced to have a redline of 5k forever? a standalone wont be able to control the throttle? someone wont figure out how to "tune" that out of the ecu (CPE)? custom throttle body?this car closes the throttle at 5000 rpms and there is no way around it.
EDIT: I am not coming on here to troll, look at my join date
lol.
yeah ur right, a 3076 cant flow efficiently passed 5k on a 2.3L.
No way around it! not only are you ignorant, but very pessimistic!
You need to stop posting untill you know somthing about this car. GO READ.(screwy)
OK guys, some day he "might? be able to use his big turbo. In my world I would of never put on the big turbo unless i could run the right amount of boost with that turbo.Go look at the compressor map for the GT3076r(lives its life on high boost)Like 1st UPGRADE THE MOTOR THEN get big turbo, But hey if you want to put a big turbo on then go slow or boom its all up to you. I am just a preemptive type of guy. Big forged internals 1st, Then bigger turbo. There is nothing ignorant about this idea. good luck!
