Got P0660 and P1250 Error Codes
Got P0660 & P1250 Codes.
Cars idle goes up like normal on start then starts to shake and die. Somewtimes flutters. Any suggestions?
P0660 - Most likely your VICS vacuum switching (solenoid) valve. Easy and cheap fix. Get two of them as the same part is used for the VTCS solenoid and the PRC solenoid, and these fail fairly regularly.
FgC4j0BB2JRfXu5Sp6MBrurP0Sqxl1opakAsJFZR2Bkp-QjVyGpbNrX-PLADnDS1qiSfxGRsM0_K1QUbBJeYkp4WFRMgdUJ1WjjpXAXuS2CK4dkCR4KwDFAv0a_4qc5ru8ZoY2ObXWqAXCWIREmHhA
P1250 - Pressure Regulator Control. I can't remember where this is located.
Replace those two parts, clear your codes, and you are most likely good to go.
Upvote 0
