T Tenc_ms3x Member : Black Mica MS3 Nov 26, 2007 #1 I got my bck but now i wanted to now is it ok if i just get a Boost gauge to monitor it.? It's says get something for air/fuel monitoring so would i get a wideband?
D Derek88 Member Nov 26, 2007 #3 silverspeed03 said: What is a BCK? Click to expand... Boost controller kit? (uhm) A boost gauge would be good to have to see what boost you are running, but seeing your safe/unsafe A/F ratio would be just as (or more) important. Provided that the BCK is in fact a boost controller of some sort.
D Derek88 Member Nov 26, 2007 #5 Sierra117 said: Boost cut killer? Click to expand... That was my second guess. (flash)
S speed3shon Member : 2007 Mazdaspeed3 Nov 26, 2007 #6 well, you can somewhat tell by others success that 17-18psi is relatively safe. you will NEED a boost gauge to set it though... you will want a wideband if you go very far with mods anyways...
