Good Place to get OEM motor mounts?
maxchao
Hi all,
I just changed out my front motor mount with SU mm. Man it makes a lot of difference. The clutch action is much more linear, wheel hop/clutch shudder is much less severe, but still present. A little quicker throttle response. Much less drive train lash. Smoother power output. Feels like more hp but I think that's placebo. All good but one bad thing the vibration. :( but thats still bearable with one new mount. Hopefully it will settle down after awhile, but I don't know if it will ever get to a point of not vibrate the dash.
It drives so much better, but bear one thing in mind that my OEM mounts had served 90k. They look terrible, I saw one side mount is totally ripped too. The new SU side mounts are back ordered and hopefully it will get here soon.
Now I'm not sure if I want to do the rear one OEM or SU. I heard the rear mount gives the most vib but I'm a little worried if I use all SU but OEM for the rear will that tear it up quicker? I don't mind to change it out after 50k for just the rear but I'm curious if there is any bad effect. I'll have my mechanic to do it anyway.
Give me some suggestion. :)
Oh and, where would be a good and cheap place to find the OEM mount?
Thanks,
Josh
i would go with the su one, i have all but the rear one done but my friends mp3 has them all done and his actually vibrates less then mine
The tearing is caused by the engine travelling too much, if you're running all aftermarket, except the rear, it will most likely be safe for the simple fact that overall drivetrain movement has been reduced.
