GI: GB on Lightweight rims...
Status
Not open for further replies.
adding a 5mm spacer to a +46mm offset wheel will make it a +41mm wheel. The 46mm wheel will almost never rub without a drop on the car and will rub with a drop. Swampbutt has a 18x8 wheel offset +48 with 235/40 tires, he rubs slightly with his mazdaspeed springs. Why do i know all of this? Cause i was looking into wheels that were 18x7.5 with a +40mm offset. I would of had to run 215/40 tires and couldnt lower the car. i decided against these and instead bought oem rx8 (18x8 +50mm, will not rub) wheels.
One sidenote: Shaving the hub mating surface of the rim is an option. Change a +46mm wheel to a +48-50mm wheel and it can save you from some tire rubbin even though we are talking about 1/8th of an inch. Some say you should never shave the wheel and some say it will and has worked countless times with people who know what they are doing.
Status
