gas for the mp3
Tzar177
Contributor
i just bought my mp3 2 weeks ago. i've been putting regular 87 octane gas in it. today i just received the owner's manual that i had to order and it said i should be using 91 octane or higher. is everyone here using 91? so should i switch to 91?
Always use 93 octane, usually Amoco Ultimate. With 1/4 tank left it costs me about $28 to fill her up. The tank usually lasts a week to a week and a half. These high gas prices suck but what can you do???
Pete
cuz my mp3 has always run with regular! myself as well as the previous owner only used regular in it. i never read the manual and didn't know until recently that it suggests using 91+ octane. i guess if i would have known before i would have used 91+ but i haven't and not one single problem. in fact it does say you CAN use below 91. only that it RECOMENDS the 91+. just because i recomend you go to your bank and wire me $100 doesn't mean you have to. the mp3 is fine on below 91 octane fuel. but yes you are likely to have better response times and engine with a higher octane.
well i put 93 octane in it for the first time after using 87 octane a couple times. that same nite my check engine light came on. now when i start up my car it seems like its trying to stall out even tho i still have the clutch down and havent even tried driving yet. think maybe its the gas? or being sumtin else and a coincidence
