Gains from a Garrett T20 & Cat-back exhaust
Soldier9521
2001 Mazda Protege
What kind of power gains would I see from a T20 and a Catback exhaust? I found a full kit for 1520.00 and an exhaust for like 430.00. Also, if I were to run about 8-10 psi would I need a front mount intercooler? Im a newb to the boost, so everything kinda confuses me. Are turbo timers necessary? What else would I have to buy?
if you wanted to turbo your car theres a lot that youd need to do to it. You would need some sort of fuel management, injectors and fuel pump. Also your stock clutch would need to be upgraded, your oil pan would need to be tapped for your oil line. And on top of all that you would have to buy all the regular turbo necessities, BOV, wastegate (unless its internal), turbo manifold, youd have to get a downpipe made. There is a lot of work to putting a turbo on your car, but in the end if you did it right and had a good tune you could hit 150whp no problem.
