Fuse for the radio?
Fabio26
Ok, I'm trying to make it so the radio cannot be used. I thought the easiest thing to do would be to remove the fuse. I have a 2009 Mazda 3 Touring. I located the fuse box and the fuse that is labeled AUDIO. I removed the fuse yet the radio still works. What's up with that? Is there a different fuse that is specifically the radio? I went through the whole fuse diagram and did not see anything labeled as such. Any help would be greatly appreciated.
Thanks!
Interesting. You did look at both fuse panels, right? You do realize that's an unauthorized mod and will void your warranty, plus install crabgrass in your front yard...
