Fuel mangament upgrades....
Where is a good place to find a Raising Rate Fuel Pressure regulator and better spark plugs? Also which would you recommend more HKS F-con, GReddy E-manage, or Apexi Power FC (might be overkill) /S-Afc?
Don't bother wasting your money on piggy backs until you have enough for a standalone. You will only be able to tune 0-4000rpm right now. I have heard of the e-manage working in open loop but never comfirmed. I'm looking at the voltage clamp that FM/FP uses on their kits to see if it will help out below 4000rpm.
Ok someone else has asked this before.
Go with e-manage. It has proven to work (except timing control)
The problems you are going to run into with a power FC of an F-Con is that: they are all in Japanese., they dont make them for our cars, hard to get, VERY expensive. I've been told that an AFC wont work on our cars thats why I bought E-Manage.
Side note about AFC: You can wire up a tps sensor to read boost and adjust fuel to boost curves. very nice. Get the Code off another topic got to www.sparkplugs.com. you have to have the product # but they r cheap. You dont need the FPR yet. but if u do umm B&M, weapon R, AEM, Cartech and some others,
