Fuel Injector Flow Rates - Add to the list
kcbhiw
What "Lifestyle"?
Contributor
64 Valves, 16 Cylinders, 7.2L, 622 HP
I thought that I'd post this in the off-topic forum so that it might gain more attention.
I'm attempting to build a list (or database, if you will) of injector flow rates and impedances for specific manufacturers and associated part numbers. However, without purchasing a load of injectors and testing or researching each, any member that might have injector specifications that they have collected/researched could be helpful to the community. Such information could be useful to those that are building the extreme N/A rocket or a F/I screamer, yet want to use an "off the shelf" injector. Below is what I have gathered from the injectors that I have collected:
Nippon Denso 195500-2180 - 230cc (13.9 ohms - high impedance/saturated) - beige top - (90-94)Mazda Protege <1.8L DOHC BP>, (91-96)Ford Escort <1.8L DOHC BP>, (94-97) Mazda Miata <1.8L DOHC BP>
Nippon Denso 23250-70040 - 295cc (2.7 ohms - low impedance) - yellow top - early ( < 1989 MY) 2nd gen Toyota Supra
Nippon Denso 195500-1300 - 300cc (13.9 ohms - high impedance/saturated) - dark/navy blue top - (91-94) Mercury Capri XR2 <1.6L DOHC B6T>, turbo Mazda 626/Ford probe <SOHC 2.2L F2?>
Nippon Denso 195500-1280 - ???cc (13.9 ohms - high impedance/saturated) -blue top - (91-94)N/A Mercury Capri <1.6L B6-DE> - N/A Ford Probe/Mazda 626 <2.2L SOHC F2?>
Nippon Denso 195500-1970 - 205cc - (13.9 ohms - high impedance/saturated) - blue top - 1.6L Miata (1.6L DOHC B6-ZE)
Nippon Denso 195500-2040 - ???cc (??.? ohms - ?) - gray - Mazda MX3 <1.8L SOHC <B8>
I hope that that this list grows. It seems that injector data is hard to come by.
Thanks!!!
