FSZE Swap (Ecu/Stand alone question)
Soundwave.
Autobots detected
2002 Mazda Protege5
So following what I have read on here, Everything will swap over and the only issue that most run into is the OBD1 to OBD2 conversion. With that I have read on here that a stand alone could be used to by pass this and get the motor to the proper 170 hp range and tuned. Would anyone happen to have any information on what kind of stand alone would be needed? This would be my first go around doing this kind of thing and seeing how I have a place to register the car that doesn't require emissions testing then this is a swap that can be done.
Also, for the FSZE swap, I could use all current sensors/plugs that are currently on my FSDE correct? The FSZE I found for sale is $500 with 30k miles with all sensors and plugs already included. Could I just use the sensors/plugs off of there or would I throw a code/ would the car run incorrectly?
Thanks for your help guys. Im really excited to be moving on with this! This is one of my most favorite cars Iv'e ever owned other than my Ae86
