FSC Inspection Required - Warning
kenkavanagh
Mazda6 GT
I've got a 2014 Mazda 6 GT and today, when I started the vehicle I got an 'FSC Inspection Required' warning on the display and the Auto Headlights and Lane Departure Warning lights were blinking on and off in yellow. I shut the vehicle off, restarted it and got the same result. hmmmm
The FSC stands for Forward Sensing Camera and I've never seen this before, nor have I had any issues with the FSC.
Any suggestions before I spend any money at the Dealership?
Thoughts?
I've read about people having this issue if they have a bad connection to the ground or if they have something plugged into the OBD 2 port. Otherwise I'd check fuses and take the cover off to make sure connections are snug to all the sensors.
No snow on the Mazda6...No ice blocking the sensors....I will check to see if I can see loose wires under the hood....argh.
Ok, just took a quick drive and no warning displayed and I didn't change or touch anything! Grrrr....I'll monitor to see if it comes back.
