FS-ZE Computer Box
if your car is OBD II emissions compliant you cannot use an FS-ZE ecu in your car
A lynx probably could. So long as you have the same wiring harness as the JDM protege. The US proteges have a completely different harness.
What if you re-pinned the ecu connector? Or spliced on the JDM ecu connector? Does anyone have the pin out of both to compare? I would be intrested in seeing how its setup.
