the valve will work perfectly on the car. In order to mount it you have to get the ATP adapter flange from Street Unit, its only $19 and it is what mounts the valve to the stock flanged area.
The flange being sold with the valve is an extra one that I have lying around and for those with a front mount intercooler and want to mount a greddy style valve they can use the flange and just weld it to their piping.
This valve works very well. phillyb and MMBOOST also got this same valve and they had no complaints.
i popped it on 2 sundays ago and it hold boost better than the real greddy does. The psi was higher as well. I think my greddy might need some teflon on it to stop what might be a leak.
Yeah it works great. It has the weld-on intercooler type flange if by chance you want to have that welded to your intercooler pipe you're good to go.
im still using my greddy type-s, so Im using the atp flange right now. But when I bought my real greddy off craigslist the guy mailed me the greddy type-s with an intercoller weld-on flange. That flange will work for your intercooler is you wanted to have it welded on. But if you want to snap it on there you'd need that atp flange
