FS: Reese Class 1 Hitch w/flat drawbar $150
This is a Reese 79154 Class 1 hitch (2000 lbs / 200 lbs tongue weight max) which I had on my Mazdaspeed Protege. The cool part about this hitch is that it is virtually invisible when the drawbar is removed when not towing! It is very easy to install with no drilling required. However, you do have to cut a small square out of the plastic on the bottom of the bumper so you can put in the clevis pin that holds the drawbar in place. Note that the drawbar is flat, not square, and sits right up against the bottom of the plastic bumper. This hitch is no longer available from Reese. I'd like $150 plus shipping for it. Package includes hitch, mounting hardware, fishwire, drawbar, clevis pin, retainer clip, and 2 inch ball. The fishwire is the flexible wire that lets you put the bolt inside the frame rail and draw it right out at the hole, no muss no fuss, and is worth its weight in gold! No futzing around trying to get the bolt positioned inside the frame rail. Don't buy a hitch without the fishwire! Located in Portland, Oregon.
Sale pending.... Please email me the details for sending the hitch to you. My email is morrisgreen AT comcast DOT net. I will package and weigh the hitch and see how much it costs to send it to Calgary, Alberta. If there are duty fees to Canadian Customs you will need to pay for those directly to customs.
No Maxx, you are the sale pending! Email me (morrisgreen AT comcast DOT net) so I can start working on the shipping part of this and get you hi res pics so you can see what you are buying!
Hitch still for sale?
Hey, man. I know this is an old post. But I'm banking on that you still have this hitch for sale. I hope so, because I want it!!
