FS MS6 complete engine with turbo and transmission
Status
Not open for further replies.
kirpich
mazdaspeed6, CLK430
Engine and transmission is from a 06 mazdaspeed6, in perfect running condition, engine does not consume oil, turbo does not leak. Engine is still in the car. Local pickup is preffered, but I will ship. I am in sacramento. Asking $3500.
It is too expensive for me to fix the body and suspension damage. I calculated, it will cost me more than $10k to bring her back how she was. Decided to sell her by parts.
can you post a pic of the exterior damage? i'm curious now what 10k worth of damage looks like...
also, how many miles, any mods, how did the wreck happen, etc would all help your sale.
Quarter panel needs to be cut where spare tire is. The whole rear of the car was swayed to the right, frame needs to be realighned. Suspension is messed up, I have not looked at it in detail on what specific part needs to be changed, but different joints are bent and some are broken. Crossmember, knuckle, Rear axle, alone would cost around 5k at the dealer. It was my own estimate, it might be less but still alot.
Pics coming up. All stock, no mods.
miles are 20k, correction from previous typo which should of been 20k. To be fully correct 19258 miles.
Does it have leather? I am in desperate need of the rear bench (rear set you sit on).. it pops up and out, someone stole mine!! Also, I will take the in-tank fuel pump assembly off you, I need for testing purposes.
Please let me know
What do you want for all 4 rotors, calipers, and brackets?
Also, all 4 struts.
who wants to guess how much this came out to be? btw no engine or frame damage whatsoever
i bet you diddent say 14K, thats how much it was for me all said and done
so u r selling the whole complete engine and trans.?like with turbo, manifold, air intake etc.? im just wondering why the insurance did not cover ur damages, and i just want to know if the engine is still good
My wife is extremely interested in the side mirrors and the lower door moldings (just above the sideskirts, not the one in the middle of the door). She is willing to drive up there to get them ASAP. She will probably pick the car apart when she gets there :) and bring help to remove all the parts.
What price you looking for on the mirrors and mouldings for now? thanks man!
If cheap enough. I need the center cubby ont he top center of the Dash. above the HEads up display!
Does the car look like this?
Rear Quarter Panel
Suspension
Was all stock EXCEPT for the "Home Depot" cai which bolted to the stock accordian tube (removed in pics), Forge BPV (which I had switched to stock after the accident), Rear engine mount, Rotora slotted rotors with Rotora ceramic brake pads, DDE Raptor Halos, Clear sidemarkers, TWM SS kit, Stubby antenna (swapped with whip antenna after accident), and other things I can't think of right now.
Also my car had around 19k miles also. Crazy coincidence!!!
Status
