azian6er said:hey koolindo, did you get in on the GB for the rods and pistons? If so have you heard any word from perf yet? He pmed me and said the rods were in but was still waiting on the pistons..
-B
YP5 Toronto said:igdrasil.....i meant to ask you this before...
you were able to do a full piston and rod swap with the engine in the car? any amjor problems in doing so?
Kooldino said:Yup, rods are in. Waiting on pistons.
TheMAN - Why not list tips and specs here? It'll make it easier for everyone.
TheMAN said:go buy the FS engine workshop manual... it's about 25 bucks from the dealer
igdrasil said:Im sorry to say that the protege workshop manual doesnt have all the specs needed for a rebuild. I had to use a 626 Chilton manual to get some torque specs.
kcbhiw said:When you're performing a tear down and rebuild of something as critical as a....uh...gasoline engine, don't you think the information would be a bit more reliable from a $25 manual (from the source) than it would be from something that has been reproduced through either re-typing or the like? Who knows what someone is posting is direct from factory print or hear say. I build engines as a hobby for race applications and can guarantee that I will NOT use specs found on a website. Granted this place is a great resource for information, but when it comes to torque specs and clearance tolerances, I'd much rather spend the money and buy a manual from those who originally produced the engine.
TheMAN said:how about NO? there are 2 pages worth of specs for EVERYTHING and I'm not going to waste my time typing it or scanning it
instead of bumming something off someone who bought the manual, why not just pay the 25 bucks for the whole manual that tells you have to do the tear down and get the specs?
lets make it easier for everyone and HAVE the manual with them while they're working on the engine instead of having to rely on running back and forth to the computer
if you can't "afford" the manual, you certainly can't afford engine parts
cablemirc said:not to mention the fact that it's illegal. that's mazda's intellectual property, you can't just go around posting all the tech specs or pages from a shop manual. giving somebody a FEW specs is okay, but re-iterating tit for tat for an entire engine rebuild is illegal.
Installshield 2 said:You were the one that asked Ed to give the specs and tips though. Tips from someone that already did the work would be valuable...I agree though, reproducing or typing the FS manual would be kind of overkill if it is only 25 bucks, thats cheaper than a pair of decent studs...
So if anyone has tips, or potential problem area info, that would be more usefull...It would help someone avoid a potential problem, or at what time to aquire some friends for extra hands...
igdrasil said:well, the piston/con rod assembly has to be removed from top of engine. This means you will need to remove the head w/ intake mani and exhaust manifold. Same thing to install them
But, you need to unbolt the con rod from the crankshaft from under the car. That means that you will need to remove the oil pan and the plate after that if you want more clearance, which has 3 bolts inside the transmission assembly, right under the flywheel in the block.
So basically I had the block in the engine bay supported from 1 mount and a tower under the block.
