FRONT Motor Mounts INSTALLLED!!!!!!
How to : front engine mount
Place car up on ramps ,If you dont have an intake ,remove the plastic over the rad so you can see the motor mount 'a word of warning dont do this when the engine is hot ,you WILL burn yourself ,also the nuts and bolts are very tight ,so air tools would be a help .
From under car look for the 2 17 mm nuts that hold the mount to the sub frame ,Undo them .
Go under the hood ,find the mount ,there is a bolt through it ,undo that bolt ,you will have to rock the engine a bit to help with the removal once the bolt is almost out .
Remove the lower mount by rocking the engine back to the fire wall .
Install the new mount ,install the bushing bolt ,go back under the car,install the lower nuts ,make sure everything is tight
no air tools, just a 17" bar with a 1/2" driver and a 17mm socket, too easy, WAY TOO EASY, you don't even need a wench to hole the bolt inplace to remove the nut, there is a flange thing that holds the bolt so it doesn't turn
