Front Engine Mounts
socrswm
2003.5 Mazdaspeed Protege
Hey guys, this may sound like a noob question, but how do I install the front engine mount? I tried searching the forums and all I can find is the how-to for the rear mounts. Thanks guys
Its pretty straight forward. Jack up the car, put it on stands. Locate the mount, unbolt it from the engine, unbolt it from the bracket holding in place. then do the same thing backwards. Its a total of 3 bolts.
if u open ur hood and just look straight down right behind the radiator then u should see it just sitting at the bottom all alone
Yeah frount and side is easy, the transmission mount is so so and the rear behind the motor/firewall is a beotch
Yeah, I've got new front and rear mounts and figured I could do the front one pretty quick and then wait for good weather on a weekend to do the rear one. Unfortunately, good weather's hard to come by up here
