front brakes sticking when hot
Fryman
when my brakes are used a decent amount (pretty much any city driving kills it) they slow stick on and get quite hot, the hotter they get the more they stick. I've been trying to figure it out but have found nothing. I took it to the mechanics and they replaced some houses and did a flush of the brake system but still not fixing it. They think its the master cylinder or something wrong with the ABS unit.
Just wondering if any of you guys have experienced something similar, and if so have any pointers on how to do it. From what the shop is saying its quite expensive to fix (if its that)
All help is really appreciated.
I would definatly try greasing the brake caliper slide pins... They are probably sticking. Make sure you use the proper brake slide lubricant...
