actually you don't have to remove the glove box. If you stick your head under there you'll see a black plastic panel. Pull down to release it. Then you'll see a white fuse panel with a bunch of big plugs in it and two thumb screws. Undo the screws and the panel will drop down. Now you can access the fuses on either side of it.
