FQ-400 - The Fastest Lancer Evolution Ever Released by Mitsubishi Motors in the UK
coolmazda5
Contributor
2008 Mazda5 5MT Sport w/ Popular Package
403bhp, 525Nm at 3500rpm, 0 to 100km/h in 3.8, 259km/h... for just 49,999 British Pounds, the almighty Lancer Evo FQ-400 is now on sale in the UK
The tenth version of Mitsubishi's iconic Lancer Evolution models has a new performance flagship model to top its range, the FQ-400.
Extreme Evolution
The Mitsubishi Lancer Evolution X FQ-400 is the fastest and most extreme version of Mitsubishi's motorsport derived machine. With 403bhp and 387lb.ft of torque on offer from its advanced, lightweight aluminium 2.0-litre turbocharged MIVEC (Mitsubishi Innovative Valve timing Electronic Control) petrol engine the FQ-400 is able to reach 62mph from standstill in an estimated 3.8 seconds before reaching an electronically limited 155mph - where permitted.
Traction and handling
Ensuring all the FQ-400's power is put to good use is Mitsubishi's sophisticated Super-All Wheel Control (S-AWC) four-wheel-drive system which appropriates power to the wheels that can best use it, giving the FQ-400 quite sensational cross-country performance.
The S-AWC system combines a number of electronic systems that both enhance the FQ-400's performance and safety, with Active Stability Control and Active Centre Differential, Active Yaw Control and Sport ABS giving the FQ-400 incredible cornering ability, traction and grip. Depending on the conditions the driver can select the most suitable set-up for the S-AWC system, three choices - Tarmac, Gravel and Snow - being offered via the wheel-mounted button and displayed in the central instrument binnacle.
Cornering stability
Increasing the FQ-400's cornering ability even further over its FQ relatives is a wider track and lowered suspension featuring Eibach springs and Bilstein Shock Absorbers. Lightweight 18-inch, nine spoke alloy wheels fitted with Toyo Proxes R1R tyres enhance the FQ-400's grip, giving it sharper cornering response on the road and more incisive steering. The enhanced agility and performance is backed by a revised braking system which uses aerospace grade aluminium alloys and floating sealed discs grabbed by high performance pads.
Extreme Power
To achieve the incredible 403bhp from just 2.0-litres Mitsubishi has had to significantly revise the FQ-400's advanced powerplant. Motorsport specification high-flow fuel injectors are fitted to the aluminium cylinder head and a new hybrid turbocharger is also fitted. The higher specification turbocharger features low-friction bearings, a high temperature turbine and strengthened thrust bearing to increase response and reduce turbo lag. Feeding the turbocharger cooled air, improving its performance and efficiency, is an enhanced intercooler, while the exhaust's gasses flow from the engine via a 3-inch diameter high flow stainless steel piping and catalytic convertor before exiting through a centrally positioned exhaust.
Mitsubishi has remapped the Engine Control Unit (ECU) extensively with over 500 hours of development time to allow its 2.0-litre turbocharged engine to not just produce its exceptional output but to do so with excellent driveability. The FQ-400's acceleration is sensational, it pulling hard through the gears regardless of engine revs. With peak torque of 387lb.ft on offer from just 3,500rpm, the FQ-400 is just as able to trickle through town traffic as it is taking a rally special stage.
A nod' to the Evo VI
The FQ-400 looks every bit the rally refugee too, giving a strong nod' to the styling cues of the legendary Evolution VI, and builds on the already aggressive style of its Lancer Evolution X FQ relatives.
A heavily vented bonnet helps heat escape from the FQ-400's turbocharged engine and a new lightweight composite front bumper incorporating Mitsubishi's trademark Jet Fighter' grille features carbon-fibre elements on its leading edges. Additional lighting and High Intensity Discharge (HID) lights mark out the FQ-400's nose, its added aggressiveness further enhanced by a 30mm drop in front ride height. Composite side skirts, a re-styled rear bumper with a carbon fibre diffuser, a rear wing incorporating a gurney strip and a roof-mounted Vortex Generator' all help manage airflow and cooling.
Behind the 18-inch lightweight, nine spoke alloy wheels it's possible to see the Alcon brakes on the front, while the Toyo Proxes R1R tyres underline the FQ-400's potency with their aggressive cut slick' tread pattern. Inside, the driver is held tightly against the FQ-400's sensational accelerative, braking and cornering forces in Recaro bucket sports seats, the range-topping Lancer Evolution X also gaining an FQ-400 liveried handbrake handle and carbon fibre gearknob.
No compromise
Despite its obvious focus the FQ-400's suspension offers compliance thanks to the Eibach Springs and Bilstein Shock Absorbers, the FQ-400's usefulness as a daily driver not compromised overly thanks to Mitsubishi's chassis tuning. The stiff bodywork not only provides an exceptionally rigid platform for the suspension to work, but excellent crash-worthiness, the Lancer Evolution X attaining a five-star score in Euro NCAP's independent crash tests. The FQ-400's S-AWC and its incorporated stability, traction and braking systems helping avoid an accident in the first place. Even so there's reassurance of seven airbags, seat belt pretensioners and ISO Fix child seating all included in its standard specification.
Fully loaded
Standard equipment for the range-topping Lancer Evolution X model is comprehensive, the FQ-400 coming with Bluetooth hands-free telephone connection, a CD-tuner with 30 Gig hard drive, DVD satellite navigation and privacy glass. Convenience features like remote central locking, automatic headlamps and windscreen wipers increase the FQ-400's ease of use, the huge performance it offers not coming at the expense of usefulness. Like its Lancer Evolution X relatives it features comfortable seating for five as well as a usefully sized boot, the FQ-400 bringing all the convenience of the standard saloon car it's based upon - but with explosive performance potential.
Setting the standard
Standard it's not though, instead the FQ-400 is a standard setter, with performance that's the measure of any rival and many exotic sports and supercars costing many multiples of its 49,999 list price. Available from June 2009, the FQ-400 is covered by a three year / 36,000 mile warranty.
Source(s):
http://www.nihoncar.com/news-1088-F...+Released+by+Mitsubishi+Motors+in+the+UK.html
http://www.autoblog.com/photos/mitsubishi-evolution-x-fq400/1195178/
That car is evil (and is only going to the UK, not even the Japanese get it)
True, although this is more of a special edition (100 units). I found this old article in Autoblog which has a couple of things not mentioned in NihonCar (Dec 08)
The turbocharged 2.0-liter 4B11 will put out approximately 405 hp and 400 lb.-ft. of torque thanks to a new turbo, retuned ECU and center-exit exhaust. As opposed to the outgoing FQ400, the Evo X-based model won't use a race clutch, so puttering around town should be bit more bearable, and due to the FQ400's prodigious output, the twin-clutch SST gearbox – which can't handle more than 331 lb.-ft. of torque – won't be used. Despite this, expect the FQ400 to lay down 0-60 times of around 3.5 seconds, 0.6 seconds faster than the Evo X FQ360.
In addition to six-pot calipers, upgraded brakes and 18-inch wheels, the FQ400 will feature a new aero kit that includes additional cooling intakes, vents, a larger air intake in the hood and ducts cut into the side skirts to aid rear brake cooling.
Production will be limited to 100 units
Source:
http://www.autoblog.com/2008/12/01/mitsubishi-evolution-x-fq400-coming-with-405-hp/
the center mount exhuast is just sick! hope top gear drives that one around the track.
Big deal... 400Hp from a X is dead easy. Sure it wont look like that with all that fancy carbon fibre and other bling, but 400Hp is a relatively cheap thing to do and in no-way even close to the money that the FQ-400 is.
A 3" Stainless exhaust system, bigger fuel pump than the standard 540 in the car, larger injectors as they starve on the standard injectors at 380Hp and an aggressive remap would see you over 400Hp. That I know for fact, not fiction.
All that nonsense of a larger cooler and what not is all just bollocks!
