Found New Header?
pimpprotege69 said:
165$ in stainless steel I might give it a go also. Just make sure you get the right one, cause for some reason there is a mp3 header and a 99+ 2.0 protege header. They are different part numbers I think.
i've been meaning to cal and ask about that, there shouldn't be a difference i dont think unless its just got a longer downtube or something.
The obx header eliminates at least one cat.
If you're looking for more torque lower down, take a look at their dyno sheet before you buy. You may find the 4/1 adds little, if any, kick at the bottom end/midrange and pushes everything into the upper mids and high end.
A 4-tube equal-length shorty tuned header usually adds lower end and midrange grunt without sacrificing top end ability.
A 4/2/1 will add upper midrange twist and provide better scavenging into the higher rev range.
A 4/1 is designed for all-out racing where higher revs are needed with other mods to provide max output.
This header usually costs you at the bottom and into the midrange.
Each is designed for specific results based on intended use. (burnout)
pimpprotege69 said:
Where's their dyno sheet?
off topic: whos the chick in ur sig?
my car has no problem through 1st and 2nd gear but my 3rd gear i migth as well shove it in 5th and coast.
i think i will get this header instead of a 4-2-1.
if anyone wants to trade me this for a racing mazda header + $ i will trade.
Off topic - Alessandra Ambrosio, been asked that so many times I'm just going to put it underneath for now on. :)
This header is looking good thoe.
The ractive headers are also now shipping, finally and I kinda trust ractive a little more than OBX although both companies seem to be producing a decent amount of product for the 2.0L 3rd gens.
Also with the amount of torque our 4cyl already put out I am not worried about not getting any gains down low.
OBX is one of the companies that makes the "ebay intake" :D
atleast I think it is
but, is this not an "ebay header" anyway?
