ok, forged pistons, just like forged anything else will be stronger than stock, yet still not invinsible. People upgrade to forged parts because in many instances, for example, those running FI applications, the material the pistons are made of can hold up to some of the regular detonation that their stock counterparts couldnt.
All in all people upgrade to forged pistons/rods as a safety measure.
Just replacing forged rods/pistons without over boring, increasing compression will not yield any significant gains unless your motor was taking a s*** before you swapped them.
Basically if one is going Naturally aspirated (no turbo supercharger ) then one wants higher compression ratio pistons, where as turbo engines opt for lower compression ratios because air is already being forced into the engine which in turn raises compression ratios.
For a goos mix of daily driving pep and weekend road racing, a compression ratio of about stock, or 9.1:1 is thought to be good. If you are building a strictly race car then i would say lower compression pistons, ie 8:1 or 8.5:1 would be better because with the lower comp. ratio people are able to boost more safely.
get it now?
--B
