Foggy Headlights
Bartron8000
1999 Protege ES
So what is the best method for fixxing foggy headlights? Should I just buy new ones, or is there a product out there to fix this?
Is it kinda' yellow/hazed? Or drops of moisture inside that go away when the sun comes out and heats it?
Do a search for the procedure to wet sand and polish the lens (if it *is* the outside).
there is no color but it is cloudy. and does that product really work? it says if you catch it early, I got the car last april and its been like this since then. I don't want to waste $50 on something that might not work.
It will definately make it look better AND most importantly, it will keep it from getting any worse.
they more than likely need to be wetsanded, then polished.
start with 1k and work your way to 2500, and then use a rubbing compound, and then work your way to a plastic polish.
im assuming you dont have an orbital polisher, if you do, after the wetsanding start with a pretty agressive polish on a orange pad, and work your way to a finer polish on white.
theres a thread on those lights...i have em too. bought diff corners tho, but id stay away from the smoked corners that lokatech sells on ebay, the black ismore of a gunmetal when the sun hits it
The other thread that discussed this in detail...
http://www.mazdas247.com/forum/showthread.php?t=123696108
the Meguiars Plast X stuff FTW
i used that on my old headlight and its like almost like brand new again
just sum scratches are still present but the lens are cleaned up good and i also took the time to clean the inside with the plast X stuff when i did my black housings again cause it looks better gloss than matte
