fog light wiring diagram
TurboColtGT
2008 Mazdaspeed 3
Anyone have the wiring diagram for the fog lights on the 08 MS3?
if so can you please post it or email it to me.
stunedspecv(at)aol.com
cause i need it for something i have in the works...
i wasnt aware we needed reasons to post a reason for needing something.
i was only thinking if you are thinking of doing something that has been done before, someone might be able to help you out. stress much?
if you are planning on wiring the fog independent of the headlights, its been done, and i could get you a link.
i am looking into maybe trying to tie a few things together.
and i need to see where everything ties into the wiring harness.
as for the stress its just one of those days... been here at work for 7am and made a whole 6 hours... man does the slow season suck
k, well, i don't have the diagram for you, but good luck with your project
Fog lights power comes in on a Red/White wire from a relay R1 in the main fuse block, with a ground to the chassis. Note that the wire changes color to Red/Green somewhere in the harness. The power to the relay contact comes from the main fuse block fuse F20.
The relay coil power comes from the headlight low beam relay, a Red/Black wire from the PJB pin J01-D. The relay coil control is connected with a Black/Red wire to pin J02-X of the PJB.
Let us know how it goes.
