I finally had some time this week between custom jobs to put my Viper Alarm in, which also made it okay to put my new Alpine INE-W927HD in. I'm not posting a how to...just gonna put some pics up. Pay attention to how the radio sits in the kit. This unit is a 7" screen that motorizes down for CD/DVD access. It ALSO allows you to tilt the screen. I hate the way it looks with the screen flat...then there's a fat lip behind the already fat lip in front of the radio. But tilt it down one step and it matches the factory angle and looks a ton better. This may help you when deciding what kind of radio to install in your car.
Radio face flat...notice the extra wide lip in front.
With a little more angle. I could put two ticks on but then the bottom buttons stick out a little, but the screen is flush with the dash kit.
My next goal is to figure out why my OEM camera is not working. I installed a 6v converter, basically a transistor with heatsink that drops voltage, and tapped my wires behind the radio. Not sure if I got the right wires and whatnot so I will work on that soon. Also, Cannot get my steering wheel module to program properly. I saw another post where they said use the same info as a CX-5 which I did, but the wire colors are not the same. I used the pin locations as my guide and I can get volume and track up is all. So I will work on that later since volume is all I care about really...and the bluetooth buttons.
