File Upload
I checked that just in case. It was already checked...
IMAX said:
Ok, Enry thanks for the "My Images" button, but there is still an issue. At least for me. First page comes up with the pics & has "insert in message". BUT move to another page & "insert in message" disappears & doesn't come back. Second, on that first page where the pics come up with "insert in message" under them. I click & get no image found. Any suggestions?
Hrm, I'l look into it... right now I've only tested with IE.
testing..
clicking "my images", i get a popup window
clicking something on the first page...
going to second page.
this is from the second page
now I will change gallery.
and another gallery
looks ok here.
enry said:
testing..
and another gallery
looks ok here.
http://www.msprotege.com/members/t3ase/MSP-Transmission-Clutch/?s=&galrows=4&galcols=3&type=popup
Clicked on "Insert in message" and it shows a new page with "No images found." Looks like a small JS error occurs before IE reloads the page with the No images found message.
Hrm.. JS error huh.
Let me make sure you understand this. This window will only work the first time it's opened. That means, you hit reply, hit my images, it will work. If later you reply to another message, it probably will give you an error because
a) the page that originally opened it is gone
or
b) the script required to insert the images is only there on 2 pages... the "new thread" and the "reply" page
So if you're on either of those pages, hit "my images" again. In fact, I may force the "my images" page to close when you hit "post" or "post reply" because there's no point leaving it open..
Yup... sounds aboot right. I'll see wut I can do about the other interfaces, but don't expect much.
Ok, Enry that was the only thing I didn't have checked. It seems to be working now. But, yes please fix whatever t3ase is talking about before I figure out what it is...
I changed everyone's editor to the WYSIWYG editor (the best one). Hope that's not a problem....
the forum seems to take exception to my two computers since i can't upload anything except avatar pictures. Can someone help me with this? My desktop runs 98se with ie6.When i try to download, it gives me the warnings others had (unable to move etc...) and the files are useless. My laptop has xp pro, can't stay connected for any length of time, and when i hit upload it simply logs out.... any ideas?
hmm...the upload doesn't overwrite files huh ? and if you delete an original file and upload a file w/ the same name but different info, it's still the same image...ODD
worst case scenario: can someone else upload them for me? (i'll just send them via e-mail or messenger...)
It didn't do that before, either.
Uploading does not overwrite, sorry. Do you think it should?
Also, I will check why the file does not change after it is deleted & reuploaded.
Also if you're having problems with any part of the site, COMPLETELY REMOVE any firewall or "protection" software you have. 99% of the problems on this site are caused by these kinds of programs. A stock install of any version of windows with IE 5 and above will work perfectly no this site. So should mozilla on any platform.
I'll try that sometime today...thanks
(uhm) Me too.
ElmoP5 said:
I tried uploading three pictures and this is the error that I got. I'm familiar with PHP coding, what should be done is make sure that there is a directory made or write some coding to detect the directory if it is not made, then create it and then move the file from the temp storage location to the destination.
ERROR:
Warning: Unable to create '/home/mazdamp3/membercontent/8195/28360.JPG': No such file or directory in /home/mazdamp3/www/vbb300/profile.php on line 2367
Warning: Unable to move '/tmp/phpOzWJg2' to '/home/mazdamp3/membercontent/8195/28360.JPG' in /home/mazdamp3/www/vbb300/profile.php on line 2367
Warning: Unable to create '/home/mazdamp3/membercontent/8195/28361.JPG': No such file or directory in /home/mazdamp3/www/vbb300/profile.php on line 2367
Warning: Unable to move '/tmp/phpOj9LLb' to '/home/mazdamp3/membercontent/8195/28361.JPG' in /home/mazdamp3/www/vbb300/profile.php on line 2367
Warning: Unable to create '/home/mazdamp3/membercontent/8195/28362.JPG': No such file or directory in /home/mazdamp3/www/vbb300/profile.php on line 2367
Warning: Unable to move '/tmp/phpisa40B' to '/home/mazdamp3/membercontent/8195/28362.JPG' in /home/mazdamp3/www/vbb300/profile.php on line 2367
