Extreme Tire Wear
chdesign
Hey everyone I need some help. I have the Racing Beat springs on my car and had it aligned 2 days afterward. I am now experiencing extreme inner tire wear on my Yoko AVSi's the inside of the tire is gone and the outsid estill has 75% tread on it. Any camber correction out there or any solutions? I can't go through tires like this I don't have that kind of cash flow. I'm getting a new set soon as this set will last maybe another week. Any suggestions I'm stumped :dunno:
Either your camber is off, or you underinflated or overinflated your tires.... you should have them at about 38-40 psi....
when you had your wheels aligned, did the shop give you a printout of the specs when they finished, so you could tell if they did a good job? maybe talk to them. when i had my car lowered, i had uneven tire wear and it was cause the car had WAY too much toe-in. if the car has too much toe-in, driving in the rain feels like you're driving on ice.
38-40PSI? You guys run your tires at race pressures all the time? That'll definitely make your ride a bit stiff and can kill the tires. I'm agreeing with the other thread that says about 32 front and 30ish rear.
I may jack up the pressures to run autoX, but it will do bad things in the long run to have them that high all the time..
JMHO
:cool:
chdesign,
I doubt that, in this case, it is the tire pressure. I agree with cjstringer on the pressures that you should run.
I think that you need to take the car back to the alignment shop and get them to recheck it. Start by showing them the problem.
