mp5jeff said:what do you mean burned through, as in destroyed the 18's??? or fenders are scratching them??
N2OInferno said:how wide were your wheels? what was the offsets on them?
N2OInferno said:Sounds good. According to Rishie the minimum offset we can run is +42 but if you do rub you could always see if someone will machine 2mm off the backs of the wheels. That's what I thought about doing since one of my wheel choices is +40. However, 8 inch wide wheels don't fit our car at all, and that was probably the primary reason for your rubbing.
By the way, I'm putting in a pre-request for pics once it's bagged.![]()
