Hi Folks,
I have a 2009 Automatic Mazda 5 Sport. I'm hearing a noise from the engine that sounds like a diesel truck, sort of like a quick splutter, "thud-thud-thud".
The first time I heard it, I was driving across the Whitestone bridge on I-95 and thought it was a nearby truck. The windows were up, so the sound is not very loud and seems like it was coming from outside. However, I've noticed the same noise while there were no trucks around and realized the noise was from my car.
The noise is only noticeable when I'm in 5th gear and the rpm is between 1,700 and 2000. Above 2k rpm, the noise either goes away or gets drowned out. The noise is slight, but noticeable if you're looking for it. I can be cruising at this speed and the noise is constantly there. I don't notice the noise while parked and rev'ing up the engine to the 1,800 to 2,000 rpm range.
So, my questions are:
1. Does anyone else experience/notice this? Is this common or unusual?
2. What could be causing this? It seems like there's an issue with the transmission, that the engine is getting overloaded while in 5th gear and it should be in 4th instead.
I had a 30k mile maintence on the car at a dealer recently and they didn't mention anything. I brought up the issue, but there was snow on the ground and they didn't want to take it out for a test drive on the highway to replicate the issue at that time. I plan on going back eventually to have them take another look, but would like to be informed before going in.
