Engine mouts and Engine Damper
Hydron
Hi
I'm tired of wheel hop but I can't stand the vibrations.
Do you think that a Medieval engine mounts combo(front, rear, side) plus a WeaponR Engine Damper can fix wheel hop with out transforming my car in a back massager?
I know but the I have heard that the damper remove some stress of the mounts and it does reduce the vibrations.
The Medieval MM have a pretty good rep, less vibrations.
or should I do only front + damper or front/rear + damper
the whole point of the solid engine mounts is to reduce movement of the engine which in turn makes the car vibrate, there not much you can do about it, honestly once you install the mounts and drive it for the first time yes you gonna go oh my god this isnt dd'able. i said the same thing but now its just a thing you learn to live with and it doesn't bother me
i have no rubber in 2 of my mounts and 1 is only half rubber. you wanna talk about vibrating you should ride in my car. my hood vibrates so loud it wakes my neighbor up in the morning.
