Engine mount question
Agent9
I bought a set of AWR mounts for my '02 protege. Got all 4 installed in short order(thanks to previous write-ups on installing the rear) but....
My silly question is how much torque do I apply to the main cross bolt going through the mounts?
The service manual gives the torque for the mounting bolts but not the main bolt(that I could find). I assume it would be different with poly mounts anyway.
Thanks!
I just torqued them all I could with a regular half inch drive ratchet. The main thing isn't how tight they are it's checking them after a day or so to make sure they are still tight.
