Engine Management Questions
p5_jeff
2002 P5
I don't have very much experience with this topic so I was hoping you folks can help me. I will be doing a motor swap and putting in a built MP3 motor that requires a piggy-back system. Can you guys give me some suggestions as to what system to use and the cost that goes along with it. The motor won't be boosted but will run higher compression. Thanks all!
Jeff
twilight runs a microtech on his n/a car...which, if i had the money i would have one too. i think they're roughly 1K give or take. LordWorm has just installed it on his stock p5 and noticed some pretty nice gains.
Jeff
here's a good place to start:
http://www.msprotege.com/forum/forumdisplay.php?f=174
here's another that a few are either in the process of using or have already (stock and high compression):
http://www.bgsoflex.com/megasquirt.html
Get the MicroTech from NSN Motorsports. It isn't a junk piggyback, but a full engine management replacement. Best bang for the buck and Steve at NSN will give you more than excellent support in getting it installed and running.
