Endlinks + Dropping the Beast
kyle's protege5 said:
Yes, here you go
Mcamster Carr has all the parts, and just get all the pieces in stainless so no worry about corrosion
Hmmm...What year is your Protege5? I changed my rear lateral link, and I don't have those bumps?!
WiL
WiL
2002 P5
someone else said the same thing, I dont know why mine is different, but I'm glad it is!
2002 P5
OK wait a minute...I got a NEW lateral bar from the dealer (mine was bent) & my Protege5 is a 2002, all my bars are straight (except the bent one). The manual pictures a straight bar...Maybe all 4 are bent? (boom07)
WiL
Allright, another new mystery, quick somebody make poll thread so we can see how many people have bent vs. straight ones & what year models have which ones.
Can someone tell me what all of the dimensions of both type of end links please? (front and rear). I think I might try making them myself.
I think my sway bar itself is what's bumping into the lower arm, though. I don't think flipping the arm upside down would help.
If you think your sway bar is hitting the rear lateral link, then pull one of the rear tires and check the area where you suspect it hits...There should be a dent or rubbing mark on your lateral link (kinda like metal to metal friction, there should be a shinny dent on your lateral link, under the sway bar). Now, if it is rubbing, you can:
A. find a new shorter/adjustable end link.
B. Raise your car up...Might be way too low.
C. Remove the rear sway bar.
Just a reminder...the end link is attached to the struts, so when your ride goes up or down, the sway bar follows...If your sway bar hits that link, you're damaging your whole suspension (struts, lateral links, sway bar...)
Also, did you shorten/remove your bump stops? If your car is that low, you will be replacing those struts often.
WiL
(deadhorse Dumb (deadhorse Dumb (deadhorse Dumb
Not a good idea. The car will roll much more pronounced without the bar and could lead to massive oversteer (drift)
Fix the problem correctly or sell the car and walk...
Yeah it's not a great idea, but there are cars out there w/o rear sway bars, and they're fine...If the guy isn't after performance then why not? Some people just like the look of REALLY LOW cars.
WiL
Yes, here you go
I really dont think those should be bent like that, I would think it would cause some unwanted alignment issues (Toe In/Toe out)
mostly i dont think I have seen any other protege like that.
Weeeeeeeeeeeeeeeeeeeeee
Tein S-Tech's on stock everything. :) Had one shock blow the first week. Replaced it w/a 2nd hand one from Anarchistchiken & been fine ever since.
However, swapping for the AWR's are on my list on the fridge.
The Panda lives on!
Good luck with the drop.
-Phil
WiL
do you mean bent as in i hit something?
I'd have to say no because they were like that fom day one, all 4 are bent exactly the same, and i have no problems what so ever getting it aligned.
Like I said I dont know why mine came that way, but I'm glad. I'd be screwed like you all if mine were straight. 1/2 hour of work flipping them over, and they will never hit each other again. As I said before, car was lowered 3" and there was still about 1 1/2" clearance between the endlink and the bar.
as i stated, they came that way from the factory, and no alignment or tire wear issues ever.
WiL
I am using KSport coilovers. It's lowered about 2". I don't think I should remove my rear sway bar. So the only option is shorter end links. Yes there is metal rub on the lateral link.
No, bought brand new, springs were put on at about 3000 and thats when I noticed the hitting so I flipped them over.
Wow...I wonder who else has this type? You might want to give your production month/year so if someone wants to do the same, they can order the bar...But at $50 each the adjustable sway bar link might be cheaper.
WiL
