Ok, so I recently purchased a set of Eibach Pro-kits. I began to dissemble everything and immediately ran into a problem (infamous stock endlinks). So I preceded to go on to the next steps. The tutorials say to jack up the control arm and remove the 17mm bolt that holds the control arm to the spindle (knuckle). However, a mazda protege doesn't have control arms in the rear. (screwy) There are "lateral links" and a "trailing arm." The only 17mm bolt I can find in that vicinity is the one holding the "trailing arm" to the spindle (knuckle). Removing that seemed to accomplish nothing. If someone could help me out, I would greatly appreciate it.
