I have a MS3 & want to get that dual port BOV but it says it wont fit with the stock air box so I was thinking of changing my intake, exhaust & maybe some other things too. I had problems before with previous cars cause I ended up running rich or lean & causing slow engine damage over time. If i change my intake, probably to a CAI... would I have to reflash my ECU & where could I do it? I'm in Hawaii, I would prefer somewhere local cause having to send it out & get it back will probably take close to a week even with 1 or 2 day air.
Woah,...you're talking about ECU reflashing to compensate for your mods (like a BOV?) This isn't possible on the MS3 at this time. You can reset the ECU by pulling the negative batt terminal (don't forget to press the brakes once or twice, this will activate the brake lights and pull the rest of the power out of all the circuits' capacitors.) But a reflash for performance isn't out there yet. We do have a stand-back from CP-E, and a piggy-back from Xede. I know the CP-E will let you run a Dual port BOV fairly well, but ideally you'd want to keep your BOV in recirculation mode 100% of the time. With just an intake and downpipe, you won't need a tuning solution, but you could still benefit from one if you wish.
Have you searched on this topic around the forum? Tons of threads have been created on the exact same topic.
Short version: Our cars benefit strongly from the following things, performance wise, and in this order (roughly)
1. Intake, CAI or SRI, your choice.
2. Downpipe/mid-pipe combo (anything cat-back only will not be all that effective in increasing horsepower, though sound will change)
3. Tuning solution like CP-E standback
4. Cam driven fuel pump upgrade (this is a new advancement)
5. Intercooler, Front mount or upgraded top-mount
6. Methanol/water injection
I'd have to say its probably a good idea for you to hunt down Nutari, who is an Islander like yourself. I don't know which one he's on, but find him and talk with him.
