Easy Protege upgrades!
KrayJay
Now when you install red LEDs in place of the regular bulbs in your tail lights it completely changes and increases the red and clarity. Do it in one tail light and just see the huge difference, especially at night.
Only problem is I did this just fine for all the bulbs in the tail lights but I can't find the correct fitting LEDs to replace the bulb at the very top of each tail light (the brake light bulbs) This is because the brake light has 4 contacts in order to go brighter when tapping the brake.
If you know where to purchase the correct fitting LEDs for that brake bulb please post here asap.
thanks
Edit/Delete Message
Try these guys;
http://www.superbrightleds.com/
The one thing you have to watch out for when using led lamps in you tail lights is that you're narrowing the angle of view. led's have a limited angle and unless you're directly behind the vehicle, may not appear as bright.
The guys above have lamps configured for a pseudo-wide angle.
