E-brake light is on when e-brake off
Porkchop2323
2007 Mazda3 iSport
My e-brake light on my tach keeps coming on and off at random times when im not even using my e-brake. Does anyone know what this might be? Car still drives fine, only problem is that light. Im driving a 2007 mazda3 i-sport.
My old Honda Accord used to do that but I was too lazy to do anything about it. Have you tried changing the fuse?
Check your brake fluid. Low fluid level can cause the light to come on. If low it
probably means the brakes are worn, unless you have a leak.
Clifton
hi my mums 2001 mazda 323f sport.. abs light and the 2 TCS plus the little red handbrake light all came on at same time! its had new disks and pads all round plus a new front driver side caliper aswell any ideas?? :/
everythink to do with the brakes :/
