Dyno Tune Results very happy
ianknight
Mazdaspeed6 06' with CP-E CAI, Custom 3' Exhaust, CP-E ems, Dyno tuned.
285.04 WHP
309 ftlb Torque
i have a custom exhause i deleted one our the cats i believe, correct me if i am wrong there is another cat on our downpipe which i did not delete
very nice. how much boost? and considering drive train loss, that would be about 315-320whp on a 3... noice.
its a dyno, they are anything but accurate based on overall output. Go to the track and see where it traps.
If anything this is proof that all you need is a boost controller as the a/f ratios are still safe and i highly doubt he added fuel. Save your money, unless you want to be able to tell people, yea im using an ems as a boost controller(dunno)
also make sure to frequently check you a/f ratio as they will change with weather.
Personally i think its a great investment! These cars run very rich i changed the A/F quite a bit. also i did not even raise the boost from stock! i guess opionions are opions but you dont gain over 45hp just using the EMS as a boost control
if its all about the trap speed laloosh, how much hp you think i have if i trapped 98.3mph?
a ms6 trapping 98 mph is probably only 250-260 max
As for the 108 car, if thats a ms6 your probably looking at over 330 if its a ms3, probably right around 300. if it a protege, 280? i dont know proteges
