Dyno today..
mazdamp3_18
06 gti, 06 evo IX
i dynoed my MP3 today.... i dont have the sheets next to me right now but ill post exactly what i got later tonight.....
but peak torque was 121.7
and peak hp was 115.9
my mods are aem intake, 2nd cat and resonator removed, 2.25piping.... crush bent:mad:
i think that the exhaust is hurting the potential... i am going to get 2.5 or 2.25 mandrel bent tubing when i get my header...
the graph is very smooth.... and i found out the power loss from the heat soak from the aem... on the hot run we lost 4lb-ft and 3 hp at peak....
the change over on the vics is very smooth.... around ~4700 rpm....
ill post the whole graph later...
Did you ever get or install that phenolic intake thing from the other thread? Just wondering if you ever messed with it.
the guy never emailed me back about it ... im still waiting for his responce so i can order it... i was ready to order it a long time ago...
my dyno run
I dynoed my car almost 5 months ago and my numbers were pretty similar to the dyno numbers above, except my car was totally stock. I pulled 114hp and 119lbs torque to the wheels. I only made one pass and it came out all curvy. I am estimating with my motr broken in it should pull a little bit better and now i have a custom short ram intake. I got a HKS Super Air Flow filter and polished elbow from a Supra TT. It sounds crazy at WOT. Want to see what numbers it will give, I will post pics as soon as I can.
