DTC (code) P0661 Powertrain, Intake Manifold Tuning Valve Control Circuit Low (Bank 1
Google
Has anyone experienced this code on their Mazda3? There's little info on it available online but it could mean the SSV Solenoid is faulty, but dealer wants to charge me a couple of hours labor to troubleshoot.
Thanks concept for the link. I didn't see that webpage you have the link to, but I saw what appears to be excerpts from it on the Mazda RX forum. That was the closest I could get to the Mazda3.
I am thinking of going back to the dealer and having them replace the SSV solenoid, apparently is seems to be the one most likely with the Bank 1 fault code or should I wait until it gets worse. Your thoughts?
Google, I would tell the mechanic to examine the connector and wiring before running a quick check of the solenoid. The Factory service manual most likely has a resistance checking step to verify if the solenoid is actually bad.
By the way, I used Bing to find that link.:D
Thanks for the info. I'll do that.
I think I should also contact the board admin and have him change my handle to Bing. (silly)
