Drive Train Warranty Questions
ZOOMit
09 Mazda 6 / 10 Mazda CX-9
I'm 3k from going over my basic warranty and the turbo is possibly going out. Need to know if it is covered under the Drive Train warranty, if not, what is exactly? The below statement leaves a lot to imagine.
Drive Train Warranty: In some cases the drive train warranty continues after the basic warranty has expired. This part of the warranty covers most of the parts that make the vehicle move, including the engine, transmission, drive axles and driveshaft. Like the basic warranty, consumable parts such as hoses and belts are not covered. However, most of the internal parts of the engine, such as the pistons and bearings, which are also subject to wear and tear, are covered by the drive train warranty.
Powertrain Warranty Parts List
The listed below are the powertrain components covered under the Powertrain Limited Warranty:
Engine
Cylinder Block, Cylinder Head, and All Internal Lubricated Parts (Piston engines)
Rotor Housing and All Internal Parts (Rotary engines)
Timing gears
Timing chain/belt and tensioner
Timing chain/belt front cover and gaskets
Flywheel
Valve Covers
Oil Pan
Oil Pump
Intake Manifold
Exhaust Manifold
Engine Mounts
Turbocharger Housing and All Internal Lubricated Parts
Supercharger Housing and All Internal Lubricated Parts
Powertrain Control Module
Water Pump and Gasket
Thermostat
Fuel Pump
Seals and Gaskets
Freeze Plugs were not added
Transmission and Transaxle
Transmission Case and All Internal Parts
Torque converter
Clutch Pressure Plate
Transmission Mounts
Transfer Case and All Internal Parts
Transmission/Transaxle Control Module
Front/Rear Drive System
Final Drive Housing & all Internally Lubricated Parts
Manual and Automatic Hub (4X4)
Front Wheel Hubs and Bearings (FWD Transaxles)
Rear Axle Housing & all Internally Lubricated Parts
Axle/Drive Shafts
Propeller shaft (RWD and AWD only)
Universal Joints
Constant Velocity Joints
Rear Axle/Hub Bearings (RWD and AWD only)
Seals and Gaskets
direct from the mazda website. and dont let the dealer tell you otherwise
Turbo is absolutely part of the drive train.
one thing to note, make sure that when you take it in bring ALL your oil change receipts (if they didn't do them). Mazda USA has been getting hammered with faulty turbo seal issues and they've been passing the buck as "you didn't maintain it".
obviously, depends on the dealer, but i've heard multiple reports of it.
good luck.
