Doors locked and can not be physically closed - CX-9 GT
MaxB2014
cx-9
My 2012 CX-9 GT has both front doors which are locked and can not be physically closed because of the lock does not allow the doors to be closed. Has anybody ever seen this? Any solution?
Sounds like someone clicked the latches shut with the doors open. If you unlock the doors, have someone pull the handle like you would to open the door normally and then take a screwdriver and manually try to unlatch the latch on the door that holds the door shut when it's closed, it should open back up.
