Does the Protege5 come with camber bolts?
I am refreshing the whole suspension on my P5 and just want to check whether the Protege5 came stock with camber bolts. Just trying to same some money if it did come stock with the car.
Thank you.
I believe the camber has some adjustment in how the upper strut mounts are positioned. However, the actual bolts from strut to control arms arent the adjustable camber type.
Upvote 0
But they are available..................
about $25 a pr or less.............
Upvote 0
As mentioned, Camber/Caster adjustment for the front is related to the position of the upper strut mount. There is no other adjustment. The rear has traditional alignment bolts for camber. The Protege can benefit from additional camber in the front, and camber bolts will help.
Upvote 0
