Does synthetic oil cause vibration?
Hi all,
This post is a spin-off from a reply to one of my other posts.
Somebody replied that they had a vibration problem, when they used mobil 1.
Is this vibration thing a know side effect of syn-oil? Or is it from using different oil weights?
TIA
vibration is not an "effect" of any oil. I'm not sure exactly what the person's issue is,b but as long as the weight is correct for the car, you should have no problem running either syn or regular.
I have mobile 1 in my car and no vibrations,now when you put AWR MM's then you have vibrations.
when i used mobil 1 in my focus it made the car vibrate. when i switched to amsoil it didn't vibrate any more.
0w20
i use mobil 1 also and i have a ? ..... is 0w20 safe to use in a hot dry climate???
mobomelter said:
is 0w20 safe to use in a hot climate? i say its too thin but others will say its fine.
Mobile1 0w20 is the same as other brands 5w20. It is perfectly fine in hot climate. I have ran it for years in my Focus and over a year in the Mazda3.
